Yes, you have to have a wire running from the coil to the center pole on the dizzy
I took it off to put back on the car it belongs to. But I found another one laying around. I guess I just find another 12v and try again.
It turns over but no spark. I got a coil wire off my other car that's made for that kinda coil. Could it be the volt reg?
No, probably not...that is part of your charging system...doesn't have a whole lot to do with ignition.
I think you just need to eliminate things... trace wires back and find out where this ridiculous high voltage is coming from.
(after work, i'm on my lunchOnly way to really tell is to test it with a multimeter. Your alternator should only be putting out like 14ish volts.
He has to get it running to test the charging system. He is getting over 40 volts with no spark at the coil.
Heh, my bad. You are right.
If the coil and dizzy check out it has to be the module. If you still have the high volts to the coil check the hot to the module if it is batt voltage tap into it for pos on the coil.
take the module to advanced and have em test it, its free. more then likely with the duraspark conversion and it doesnt spark its the box. coulda messed something up with the wiring, also push the coil end of the coil plug boot up so the nipple that goes into the coil is showing, and test to see its fully seated in the coil, then push the boot back down
