85_Ranger4x4
Wallers in rivers
TRS Event Staff
💻 TRS Socials
OTOTM Winner
- Aug 7, 2007
- Frankfort
- State - Country
- IA- USA
I think this is where I'm at now - I never even tried to use the original TFI coil for this setup and have only attempted using the round oil-filled coil, and even after installing a ballast resistor it still acts the same way. I also tried powering both the coil and the Duraspark module directly off the battery, same behavior. What am I going to have to rewire and do otherwise if I yank the ECU out?
Mine was a 2.8... and this was like uncomfortably close to 20 years ago.
The ECM getting tach signal was the only issue I had. Computer has nothing to do with anything as long as you don't have an A4LD or cruise control.
I think cruise just tells the ECM when you are using cruise and it may pick a different algorithm or something. I didn't add cruise until after I had ripped the ECM out and it works fine.
