So, you have put your testlight or voltmeter between the coil negative and the engine block, and when you crank it, the testlight is not blinking correct?
Here's a link if you still want to mess with it. Sometimes you have to walk away and leave it sit for awhile, and then get back at it.
The Duraspark II ignition system debuted in 1976 with the intent to make substantial increases in secondary voltage and extend system maintenance intervals. Spark plug gaps were widened to take advantage of the heightened current and to prolong spark plug life. Special testers were devised at...
itstillruns.com
