I have all autozone clutch components in mine. I just did a new clutch (everything) while the trans was out for a suspected leaking rear main. They were almost all AZ part installed and when we pulled the trans I just took all back and got new again at no charge. I have been az parts for over 100000 miles with no issues. The one slave they gave me initially was sent back as it was defective at the throw out bearing collar. They took it back no questions.
I have in the past installed the premium brand ones and they lasted no better than any other, plus had no long term warranty! All parts are subject to defects and AZ is no different. OEM can be bad, NAPA are from what Ive been told all from china now also so everything is pot luck. Yes it is a PIA to redo but just think if it had been a premium brand you would be SOL.
Forgot to add, if changing one part be prepared for the other to fail. I did the slave only master failed, did a master only slave failed! These were not AZ parts BTW. One was the premium slave the other was the master on the truck when we got it.
