dual battery info
predator
elk mound, wis
i didnt know where to put this so if it needs to be moved i apologize, i want to put dual batteries in my explorer, i already have the tray and battery, i just need to know how to wire it in. i am installing my winch and i want the winch to run off the second battery. i do not want the 2nd battery responsible for anything other than the winch and the lights. but i do want it hooked up so that it is charging off of the alternater...any help is greatly appreciated!!!
also, i know i have seen people install a window wiper fluid and rad overflow from a different vehicle in their rbv to make room for the 2nd battery, what vehicle should i pull the resivour out of?? thanks again!
I used an Isolator for my setup,Started a write up a while back but hadnt had time to finish it.Go to the search bar and type Dual battery setup on here.
There is a ton of info,just Google it..
i did a search, the problem is i come back with too many results and i am even more confused than before i started....too many options, i need a wiring diagram, pictures are worth way more than a 1000 words...
