Drop pitman arm
Lower the height of your lift or swap to a custom steering linkage that matches up better with your lift.
So really these are my only 2 options, i thought alot of people on here were running the 6 inch lift with 33's and the extreme drop arm and had pretty decent steering angles, i'm pretty bummed out
To be frank, the arm that is on your truck does NOT look like a FA600 arm to me. You're saying you measured it and that the end of it is 7" below the frame (which would be 4" lower than a stock arm would be), so I don't know what else to tell you other than that yes many people do infact run the FA600 arm on a 6" lift and do have acceptable performance with it.
The first arm pic you posted seems more like a FA600... If it is (and the one on your truck is not), then it should be plainly obvious that it's a way bigger arm (much like as in the examples alwaysfloored posted).
