Driveshaft or driveline question- one piece swap
RobinHood
Henderson, NV
l have read throught the various posts on the site about the swap... l am picking up a drive shaft tomorrow from a 2001 Ranger Ext. cab for the one piece swap.
My question is... what parts should l be removing as well? Should l be taking the flange from the donor vehicle off the T-case as well? IS that the best way to do it, or is it easier to buy the fitting from the auto parts store and use that?
l am aware that the axle side flange will fit fine, but what parts should l be taking off as well to make this swap go as easy as possible? essentially all options are available to me, what is the CORRECT way to do the swap?:icon_thumby:
One final thing, is the 2001 aluminum or steel?
well i'm going through this know i would say get the flange just to be on the safe side. i have a 2.5" flange and the new shaft has a 3" flange. So now i'm trying to find a 3" flange or a new u-joint so i can use my 2.5" flange. and if the flange you get is a 3" and you already have a 3" then you can sell me yours lol.
Yeah l saw your post right below this one...
If it works out that l have an extra, you can have it for the price of shipping... cool?:icon_thumby:
well if they will sell it to you i'll pay for it if its a 3" flange. I just went to my Junkyard and the won't part it off cause they said then nobody would be the t case. so right now my only choice is new u-joint that i can use my stock flange. but i would rather have it done the right way.
l am picking it up private party... so it shouldnt be an issue. It is from a rolled ranger they are just trying to get rid of.
you should have no problem.. it should be a bolt in swap.. i put a one piece in my 95 an i literately unbolted old shaft an bolted new one in and got rid of the carrier bearing cross member. you should have no problems..
well my new shaft had a 3" flange and was a steal shaft. so i had to get a combo u-joint. no big deal really problay needed a u-joint anyway. if you run into this problem i have the u-joint part # if you need it. save you some time with the idiot's at the parts counter.
Cool... so the driveline has the bigger flange and the private party didnt have it. l will need that part # from you. IS there a reason you didnt get the new flange? Apparently they are only twenty bucks.
$20 where the hell at? i figured the dealer would want way more then that. and like i said before the jy wouldn't part them off and i didn't wanna spend 2 weeks finding one. So the hell with it i bought a new u-joint problay would have needed it anyway. but the part # is 353 and its a precision u-joint. not sure if the part # is same with all brands but there you go.
I got mine from a 98' and it bolted straight up to my 97'...?
-andrew
Unfortunately l picked up one from a 2001... a 98 would have been nice, but this 2001 aluminum driveshaft was free. So now l just have to figure out the mating surface difference.
just use the flange off your old drive shaft and get the combo u-joint thats what i did. worked out just fine.
