Drive line question?
AK Bronco2
1999
Hi everyone. Will the front drive line from an 85 automatic fit in an 84 manual? Along with the 84 I was given came an 85 auto. Im hoping I can take the front drive line off the 85 and put it on the 84 because the 84 doesnt have one currently. Are they the same length?? Thanks!
I don't know offhand but you could just go pull a tape on both drivelines and find out...
Thanks Shran, parts car is a 15 miles away. Was hoping I wouldnt have to make another trip. Off I go!
Here I go again, can't help myself. :icon_twisted: Teacher once, teacher always. Typically, when you refer to a driveline, it's a term meaning an assembly. Vehicles have drivelines, consisting of a transmission, a driveshaft, differential . . etc etc etc. The piece you reference, is a driveshaft; part of the driveline. I know lots of people, places, etc, use the term driveline meaning a driveshaft . . . but just because they do it, doesn't make it right. Two wrongs, makes no right. Hell engine oil says motor oil on it!! wrong!! I just couldn't help, just tryuing to fix the world one step at a time :) ha!! Have a great day. :yahoo: Hope you found what you were looking for at the yard.
^^^ Now I understand the OP's question. At first I thought it was so self evident that I didn't respond as I would have been an asshole about it.
Richard
You make a very valid point that gives me a very valid but dishonest idea.
I wonder if I could pour "motor oil" in my starter blower motor and then sue the oil manufacturer when the blower catches on fire since I used "motor" oil to lube up the only actual motors on the vehicle.
I mean, the new business of America is suing other people for one's own stupidity, right?
Merriam Webster defines the word "motor" as "any device that converts another form of energy into mechanical energy to produce motion"
By that definition the term "motor" is an entirely accurate description of an internal combustion engine.
It's also no surprise that Ford Motor Company and General Motors use the word in their names.
This is a case of "all squares are rectangles but not all rectangles are squares" in the same way that a square is one specific type of rectangle, an internal combustion engine is one specific type of motor.
Lulz. Here we go again! I'll give an example of a large national parts/service corporation (Inland Truck Parts) that builds drivelines. When I hear "driveline" I think of the shaft connecting a transmission/transfer case to something else... "drivetrain" refers to the engine, trans, t-case, etc.
I'm sorry, that is incorrect.
The engine and transmission are part of the power train. The transmission, t-case, shafts and axles are part of the drive train. The shafts and axles are the drive line.
I'm with ya on that adsm
So the transmission is part of both? :icon_confused:
Why is the t-case often covered under "powertrain" warranties then? Also, all the other pieces, such as the axles, CV shafts, wheel hubs, etc?
Furthermore, assuming (all semantics aside for the moment) that "driveline" = "driveshaft," this implies that either word is referring to the part connecting the transmission or transfer case to the axles, NOT the axles/axle shafts/hubs/wheels etc, correct? Therefore, using that logic, the term "driveline" ≠ axles, axle shafts, hubs, wheels, or any other driven elements. Right?
:thefinger:
go to a reputable parts dealer online and search both parts and see if the part numbers are the same for both applications
Measured. Very close but not enough. I'll buy one.
I just looked it up from NAPA and the manual and auto have different numbers, as well as different numbers for u joints
You are correct sir. Sorry to create such an issue with the language/wording of my post.
