doors...bummer
willievhook
Toledo, Oregon
Okay, tonight me and a couple of my buds were out trailriding, and I was backing up to turn around. Because of my window tint I can't see too well out of my back window, and i dont really use the mirrors, so I just open the door part way and look out it. Well, the bottom of my door got caught on a stump, and bent my door forward. Had to beat on it with an ax to get it to shut, so I need a new one.
My question is, what kind of doors will fit? I have a 93 extended cab
Also, how hard would it be to upgrade to electric locks/windows?
Thanks in advance
you should be looking for doors off from a ranger from 93-97, as they are all the same. as for the power window upgrade i would say as long as you have the wires going into your existing door it shouldnt be too big of a deal, and even if you dont you could trace the wires back to a plug inside the interior when you find the donor truck and then check the same spot in your cab to see if you have the plug to plug into.
Doors from 93-2010 are all the same.
