door ajar light
jcwest1
Does anybody have trouble with the dome light not going out & the door ajar light on the dash staying on even with the doors closed-of course! After I drive a mile or 2 down the road it all goes out! I can't find any door switches in the rocker panels:icon_confused:
The switch is on the door locking assemble inside the door and the tip just get stuck on the switch and all i did is pull the switch out and clean it with brake clean and pack the tip with grease and then cycled the tip in out to make sure the tip was lubed.... I will try to post up pics later
Sorry but it's a very common problem. there are no button in/on the door opening as in the past. The switch is now incorporated in the actual door latch. Open the door and really spray in there with WD-40 or PB Blaster. Had to do it a couple of times on mine before the problem went away.
Dave
Thanks guys- I'll try both & see what happens
