- Aug 6, 2007
- Age
- 40
- Western Mass
- Automatic
it looks like this time the axle is ok, and i have spare caps from the last failure, so this should be a quick fix.. (right side inner, last time i broke the ears off the slip yoke)
i was not hammering on the truck, and hadn't at all that night on the trail.. i got into this wash out section, and decided to see if i could fully flex the truck out for the first time. (lockers f/r now, and matching 4.56's finally)..
below is how the right side was when it happened.. i was creeping forward in 4 low, and it just went POP, i backed up a few feet and hopped out with a flashlight, found the cap and seal, didnt find either circlips.. the right rear tire came off the ground as i pulled forward more, so that probably put more force on the right front
then i'll cycle the suspension and see whats up.. btw i never did figure out my alignment problem, the right side i couldn't get the camber in spec, if you remember.. im kind of just waiting till i get a super runner kit, then try and get it aligned again, hoping the coils settled or something
i have it zip tied to the shock to keep it away from the tire, but that causes it get pulled when i droop..i originally did it to pass inspection (guy was being a dick, he made me change the stock way of it running in front of the coil, maybe he read the tech article, lol) if it flexed anymore it would probably break, but i'm pretty sure the shock wont let it..
