Does this go with this??
d35s dont all have thrust washers.
86
i don't know what you call it but the splined washer that goes on the stub shaft and is retained by the clip is on all d35's.it holds the stub shaft in and the seal tight on the back side.
I hope to wheel this weekend
Shouldn't need an auto hub socket unless you are actually reinstalling the auto hubs. Once the lock key is out, it should unscrew with a large pair of Channellocks, it's not very tight at all.
The C-clips & splined washers that are there can be reused as long as they're in good shape (generally they are, like the ones in your pic appear to be). If not, then you'll probably have to get them from a junkyard. Dealers may or may not have them.
Thanks for clearing this up Junkie, I couldn't remember if the auto hubs had the same washers and such.
dont but the conversion kit for 50 or whatever, call four wheel parts, and tell them this part number 28068x, they dont show it on the website, but they stock them and they are $9 a bag, you need two bags, and its everything you need to convert, i just did mine yesterday and it was perfect
I dont have a FourWheelParts. And I live in an area of inflated economy. I paid $60 for my kit. And I think i'm ok with that. I spend just under 1 hr of time calling around town to see who even HAD it, and got paid for it the whole time, cause I was at work, drafting while calling. So, whateve'
