I'm seeing $144 from NAPA for that set pictured above. And like was mentioned, make sure the kit is comparable in what comes with it. I go to NAPA because I hate lines. The prices aren't different unless you are buying really cheap parts at Autozone, which I avoid.
You MUST use new headbolts as they are torque to yield, which = torque to failure. They are ruined after a proper tightening. And like other's have said, find out why it failed before dumping money into it. Head gaskets don't simply blow out.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
