Do i need drop brackets or extended brake lines?
93_RangerSC
Charleston, SC
Alright a couple of quick questions. This summer i am lifting my truck up a lil bit. hopefully around 4". im going to have a 2"BL and a 2" suspension from Fat Bobs Garage. would i have any problems with camber or my brake lines?
with only 2" up front your brake lines will be fine, you will need an alignment afterwards. You won't need drop brackets either with that amount of lift.
True, but the body lift wont have any effect on how much 'lower' the axles are from the frame, which is what applies the need for drop brackets and ex brake lines.
yea your right..
thanks for the help yall
