Divorced 205 in
looks good, do you know your crawl ratio yet? I wanna see a vid of Low/low :headbang:
Sweet!
I'd like to know the crawl ratio as well.
don't you want the front drive shaft connected to the np205?
or are you not at that point yet?
I'm guessing he is not to that point yet.
looks good!
how much does it weigh?
How you going to get the driveshaft around the front t case? I'm doing the same with my Scout but i'm using a driver side output np231 and a passenger side output Spicer #20 with a divorced Novak adapter.
looks good!
Married NP205's weigh 147.5#. I didn't weigh my divorced one but 150# is close.
My own plan is to use GM axles and go the other way with the shaft.
i was planning on doing the same set up. (KINDA). I have a 4r44e, bw1354, and 3.00:1 lo max np 203 and 4.56 dears that i am going to use. Final crawl is somewhere around 83.80 if my calculations are correct. but i dont know...
