Difference between ABS and non-ABS
Trollbait
I'm likely going to have to replace the rotor/hub soon. It's a 2WD, rear ABS, and torsion bar suspension. I've been pricing out some and noticed that the 4 wheel ABS are generally cheaper. Cross referencing the part on the Bendix site tells me to use the 4 wheel ABS rotor.
I know that the ABS rotor has an exciter ring, but is there anything else? If not, is there any reason that I couldn't or shouldn't use the ABS rotor on a non ABS wheel?
i think the ring is the only diference i dont see why you would have a problem..
