Diff fluid recommendations
BobSacamano
Forum Member
⭐Supporting Member
Brookhaven
MS - USA
Other
2021 Bronco Badlands 2 Door
Vehicle
Drive
Skyjacker Leveling Coils
31x10.5x15
I’m about to install my “new” 8.8 4.10 limited slip rear end. I thought I would go with the recommended 80W90 gear oil with friction modifier.. I see Castrol makes this gear oil with the friction modifier already added. Does that sound OK? I don’t do any heavy towing. Or should I go with a heavier oil since it is used?
I wouldn't overthink it too much, standard gear oil then adding modifier is fine or the synthetic stuff with the modifier in it already, either works fine, it'll appreciate just having oil :)
OK. You’re right. I probably am overthinking this. I just wanted to make sure I was doing what was appropriate. It’s been a learning experience dropping the axle in my driveway and putting the new one in by myself. Ha ha.
4 ounces of the friction modifier or should I do two and see how that goes?
Personally, what comes in the oil seems like the right amount for me, but I like a harder lockup. Assuming you use an oil with modifier. The more modifier, the smoother the lockup and less grabby it is. I don’t mind if it makes the tires chirp feeding it gas on a sharp turn, that tells me it’s working. I’ve done the extra clutch disk to mine too.
