Diagnostic tool. lab scope. graphing meter
turboranger2.3
vancouver island. bc
84 ranger 2.3 t
Who plans to stay an automotive enthusiast ( ranger fan)
I'd like to know how many have a lab scope or graphing meter.
Why its needed ?
Why its not needed?
What is it?
Remember its 2010
needed because you can monitor sensor output voltage over time and watch for dropouts or static, ect. and then pause and review. some also take snapshots
what can you tell from this capture? you would NEVER be able to see this problem without a scope
i use the snap on MODIS at the shop i work, but i plan to get a PC based lab scope for home use, they are actually pretty affordable
Bruts is with the program. good man , imposssible today with out.
Fluke 99b 100hhz
fluke 97 50 hhz
todays standard that is slow
AES wave form manager/laptop
OTC perception
FOR the home mech. there several great choices
Built in database perception. snap-on. and others have it.
THIS is cool.it has a the wiring diagrams and pin out numbers.. system description.for most vech. and components.
like for ranger 2.9 TPS
describe the system
show you a wiring diagram and colours just for that curcuit
pin out numbers
graphing meter or scope, will work on any electrcal system in you house
once you have one. all kind of avenues open up.
OTC perception remans $500 second hand cheaper
With inductive mili- amp pick-up add, to you system
a hole, nother world, open up.
check this out.
With inductive pick up.you can measure amps on any electrical device
From you bed lamp to you vech.
On fuel pumps you see commutator wave form. if one is bad you can see it
Going on a long trip.? I'll tell you if theres a chance of that motor landing on a dead spot.. that cool.
after throwing hundreds of dollars at your car. It won't take long to pay one off
IT will follow you your hole life.and you will be in tune with the modern world.
that cool,
another plus is that some have ignition scope capabilities. i've used this on the modis to track down a cracked spark plug causing lack of power in a brand new 380hp ford 302.
and another time to find molten spark plug wires causing backfires in a motorhome where access is limited to actually get in and check
There has to be more people with data based lab/graphing meter
THere so cool=less ball busting.
IF you have one ,you will never go back to diagnosit dart!
I wish I knew what one was and how to use them. I love working on cars. Unfortunately for me 4 times I tried for shop in high school and always ended up with home ec. Lucky for me Im a persistent bastard and spent the last 16 working on my owns cars whether or not I knew what I was doing. I learned alot. I daignose almost everything by common sense, hearing, and process of elimination.
OTC perception. google IT.
Designed for the stupid monkey.
In the data base there is sensor decriptions. how they work. it loaded with INFOMATION.
SO COOL.
THIS IS SO FUNNY. !!!!!
WHAT ARE YOU DOING NOW. THINK THINK THINK
You are on a computor. with hundreds of possibility. you might play PC games.
That OTC perception --- .Lab scope- graphing meter.
IS f--cking easier to use.
iTS made for us. COOL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
FEELINFROGGY. A persistent bastard. IS GOOD. YOU would nail it. you will updated. (2010). save time. gain knowledge. you got 50 yrs ahead. dont fight it. youll love it.
Then you will teach them. IT all attitude.
