Deisels
Natedog
CA
Early 2.2 & 2.3 Diesels
(Still gathering information)
Engine Identification
(8th digit in the Vehicle Identification Number)
Vin Code Engine Size Cylinders Manufacturer
P 2.2 4 Toyo Kogo
E 2.3 4 Mitsubishi
General Engine Specifications
Year Engine Net Horsepower (@ rpm) Net Torque (@ rpm) Bore X Stroke (in.) Compression Ratio Oil Pressure (@ 2000 rpm)
1983 2.2 59 @ 4000 90 @ 2500 3.50 x 3.50 22:1 51(3)
1984 2.2 59 @ 4000 90 @ 2500 3.50 x 3.50 22:1 51(3)
1985 2.3 86 @ 4200 134 @ 2000 3.59 x 3.54 21:1 11.4(4)
1986 2.3 86 @ 4200 134 @ 2000 3.59 x 3.54 21:1 11.4(4)
1987 2.3 86 @ 4200 134 @ 2000 3.59 x 3.54 21:1 11.4(4)
Notes:
(3) @ 3600 rpm
(4) @ idle
Tune-Up Specifications
Year Engine (warm) Valve Clearance Intake (in.) (warm) Valve Clearance Exhaust (in.) Timing ATDC Injection Nozzle Pressure (psi) Idle Speed (rpm) Cranking Compression Pressure (psi)
1983 2.2 0.012 0.012 2 1957 700 427(2)
1984 2.2 0.012 0.012 2 1957 700 427(2)
1985 2.2 0.010 0.010 (1) 1707 (1) 384(3)
1986 2.2 0.010 0.010 (1) 1707 (1) 384(3)
1987 2.2 0.010 0.010 (1) 1707 (1) 384(3)
Notes:
(1) See Underhood Sticker
(2) At 200 rpm
(3) at 250 rpm
Capacities
Year Engine Manual Transmission (pts) Auto Transmission (qts) Transfer Case (pts) Front Axle (pts) Rear Axle (pts) Fuel (gal) Cooling WO/AC (qts) Cooling W/AC (qts)
1983 2.2 3(1) 8(2) 2 2 5 15 10 10.7
1984 2.2 3(1) 8(2) 2 2 5 15 10 10.7
1985 2.3 3(1) 8(2) 2 2 5 15 13 13
1986 2.3 3(1) 8(2) 2 2 5 15 13 13
1987 2.3 3(1) 8(2) 2 2 5 15 13 13
Notes:
(1) 5-Speed Overdrive Transmission: 3.6 pints
(2) C-5 Transmission (2wd): 7.5 quarts
