dana 50....or dana 60?
you guys would shit yourselves if you saw what i paid for this truck. it was a wreck every body panel but the tailgate was worthless. it was beautiful... 80,000miles. the truck was in "new" condition.
what kind of motor did it have? 7.3 powerstroke? sellin it?
lok at the housing, if its got 229 stamped into it its a 50, if its got 248 stamped its a 60, i did the same exact thing, got a 2000 f250 superduty for 600 bucks with the title, pulling the axles tuesday and selling the air bags and steering column, scrapping the chassis for my money back :)
All single rear wheel superduties from 99 to 01 came with a dana-50. Only the duallies had the dana-60 those years. In 2002, ford put dana-60's in everything.
On the superduties, you've got metric 8x170 bolt pattern, unit bearing hubs (super spendy on the fords, 300-ish per side), and vacuum operated hubs, but they are disc brake (anti-lock on 2000 and newer).
Early 99 trucks had smaller sector shafts, and smaller track arm bolt hole, hence almost no lift kits for early 99 trucks (built before 3/99 on door sticker).
Superduty VANS on the other hand, to this day still use the older 8x6.5 standard bolt pattern wheels!!
Unit bearing hubs on superduty axles suck once you put a big tire with tons of wheel offset. DYNATRAC sells a conversion kit that turns the dana-50 outters into dana-60 outters, gives you a fixed spindle and manual warn hubs. They also sell a crossover steering kit that replaces the outter knuckles. Awesome kit, but its 3000 bucks for everything.
That said, I dont personally know anyone that has destroyed a superduty front axle. Dana 50 or dana-60, and we drag race and sled pull the crap out of them. 4-wheel drive, 20lb boosted launches on pavement with 35" tires and 8000lbs of total truck weight.
Lets just say you wont be seeing any 1 ton chevy IFS trucks doing that more than a couple times. I have about 7 race seasons of doing that to my truck.
