dana 35 hybrid rebuild
spikeike23
i am looking for somewhere to buy a ring and pinion set for my axle it has 4.10 gears and im not sure if i need to go with dana 28 or dana 35 ring and pinion sets. any ideas what i need to look for and where i could find the gears it would be greatly appreciated.
You have 4 options:
1- With a hybrid you'll need a D28 R&P. This seems strange though....most hybrid axles were 4.10's....mostly behind 4cyl's.
2-Find a hybrid axle with 4.10's already, and swap in.
3- Upgrade to a "true" D35 and regear it. Swap it in along with the proper inner shafts.
4- Find a already 4.10 geared D35 chunk and swap it in. J-yard from a 90-92 4cyl Ranger.
Finding a center section that's alreay set-up will greatly lower the cost. In my opinion, the hybrid is not worth regearing, and the only way I'd keep it is if I never played off road and already had the 4.10's. Either way, I see this as a chance to upgrade, and spending money to regear a true D35 chunk is money more wisely spent. Good luck.:icon_thumby:
ok now that i know i need a dana 28 ring and pinion where can i buy it from? any suggestions?
Guys...
If he has a Hybred D28/35 he MUST get a gearset made specifically for the hybred.
The pinion in a hybred has a longer shank.
a conventional D28 pinion won't fit the hybred housing.
AD
does anyone know where i can get the gearset thats made specifically for the hybred, or is ford my best option?
Didnt know that. I should have though.
Well shoot....
I didn't know that either. But we're always learning!
Seems to me like your best bet is to snag a hybrid center section with gears already set. Want mine? For the right price I'll rip it right outa there, since I'm planning on upgrading sooner or later anyways.:rolleyes:
Or just swap in a true D35 center section.
how much would you want for yours and where are you located at?
Don't waste time on th hybrid. Swap in a D-35. Look for a Sploder with 4.10's already installed and swap both front and rear axles. You will have a much stronger setup that way. The Hybrid and 7.5 aren't worth spending money on and you should be able to pick up a set of axles cheaper than getting gears installed.
No 4.10s in TTB sploders (look in '90-'92 4cyl trucks, some of these had 4.10 D35s)
REAL D35's out of gen2 4cyl 4x4's are few and far between.
I happoen to know where there's a hybred D35 chunk with 4.10's, but it
seems kida pointless to swap in a hybred when swapping in a REAL D35
is no more difficult.
If you have to buy gears I'd recommend getting ANY D35 chunk from a junkyard
(or one of the yard crawlers who answer posts in the WTB forum)
and put REAL D35 gears in that.
AD
