i need some info. about a (SAS) i have a 1990 ranger that i want to convert into a solid axle with the dana 30, can someone give me some info has anyone did this before.
the yj dana 30 is a hp and is considered the strongest housing when you get rid of the vacuum disconnect by using a tj shaft instead of the 2 piece shaft. however the xj axle is less of a hassle and you get the larger u-joints on the later models... i think 96 and up.
