Best Dana 30's are the 95-99 jeep XJ'S. These ate high pinion, and don't have the central disconnect.
2000-2001 Cherokees use the low pinion, and the pre 95 has a central disconnect which isn't ideal for most people. Uses vacuum to disconnect/connect the passenger side shaft.
So, 95-99 is what you want.
