dana 28 axle crap
I never broke the Dana 28 on my Bronco II, blasting it through the desert.
Something is wrong. If I remember right, that shaft has TWO joints. Perhaps the OTHER joint is binding? Or maybe the shaft is binding in the spindle? Hitting a balljoint (it shouldn't, but it's kinda close to the lower)?
yea the juknyard here wants 150 for a 93 explorer axle so what do you do about the automatic hubs? an you need all the steering stuff? wat about radius arms
You need Dana 35 hubs with a Dana 35 axle.
I have a working set of 1991 Explorer auto hubs if you need them (from a manual hub conversion; they are fine), along with its hardware.
You need at least the spindles. I suspect you need the steering knuckles as well. And if you need those, you'll need the axle arms because the upper balljoints and camber adjusters are different.
the guy at the place i ordered it ordered me one froma 93 explorer with manual hubs an everything hub to hub he knew i was putting it in my ranger so that was cool
