d44 steering question
Ruff Stuff has tapered inserts for the knuckle. Do y'all reckon they would be as good as reaming the knuckles?
No. They're a PITA. You really SHOULD weld them in. Plus they don't fit the standard t.r.e @ the pitman arm as the taper is larger.
I had good luck with the ruffstuff inserts. My knuckles were already retapered for 1 ton steering but I had to use an insert on one of the steering ends that the drag link attaches to, so I could run the tie rod under the knuckle. No experience using them on knuckles themselves. Find a buddy or Offroad shop with a reamer
