- Apr 18, 2008
- Age
- 88
- Austin
- Manual
Twizzler
If the present plug is in there tight there is NO CHANCE! To find that noise why not start the engine cold and raise the hood and apply your hand to varioue places to FEEL for escaping pressure?
If you have an exhaust leak that in itself can cause a burnt valve.. ALL exhaust leaks need to be repaired specially those near the engine.
Stop trying to blame your present miss on yesterdays loose plug. If you are so worried why not simply unscrew the plug and then reinstall it to see if it is wasted or doing it's job. We cannot trouble shoot your miss till you sort it out and tell us what is ISN'T! Give a little help here. Oh, and I would advise installing a NEW plug instead of the old one..
Big Jim
Actually, Big Jim, I do have a noise that sounds something like an exhaust leak, and its coming from the driver side of the motor. The same side as #5.
What are the chances that the loose plug from last year screwed up the threads or something and is allowing air to escape through the plug hole? Escaped air would also explain the miss, a rather rich mixture.
Big Jim
