I happened upon a set of D35 beams and arms for free. I've been reading whatever I can find about cutting and turning.
I want to run 3" of lift, to match the coils I have. With some simple trig applied to the length of the beam, and the change in coil height, I have decided I need to build 6 degrees of camber correction into the beams.
This was using the length from the pivot to the coil seat center as the hypotenuse, and the coil heights as the opposite and relating them to give a sine. Discovering the change in the sines of each relationship, and then inversing the sine, I arrived at a little over 6 degrees.
I'm thinking I can make one cut into but not severing the beam, and heat and bend it. I want to make my cuts somewhat close to the pivot bushing. I can monitor how far it has been bent by measuring the gap being opened up.
Is this all that is required for camber correction? I'm somewhat leary to believe it is this simple. I know that lift kits drop the pivot down, and with a taller coil, the entire beam is dropped in hopefully the same position just vertically displaced x inches.
I don't see my simple cut offering a drop matching the increased height of the coils. Will it be necessary to completely sever the arm, and incorporate x inches of drop AND 6 degrees of camber seperation? Or will a cut and spread be sufficient? Of course the alterations are gonna get plated.
If you guys see any flukes in my reasoning, pick on me for it. I just finished my freshman year as an engineering student. I feel I am going to need to build a jig where I could bolt the knuckle flat and vertical, and figure from there. I better go buy an angle finder, too. Any help is appreciated.
