crusie control question
kaytor692
my 86 has crusie but it isnt workin i have vacumm at the vacuum controller but it dosent do anything is there a way to check the signal stat for power? or any comin problem with the system?
I had the same problem with my CC and found that the cable was stuck to run the throttle.Sprayed some lube in it and freed it up it runs fine now
hmm ok ill have to try that thanks
