Crankshaft Mysteries - Please Help w/ pulley bolt torque spec.
inov8tn
Hi all -
My manual seems to lack the torque spec for the 4 bolts used to attach the serpentine belt pulley to the front of the crankshaft.
It didn't take much to remove them 20-30 ft-lb but I'd like to put them on right.
Also, would using some blue Loctite on them make sense?
Thanks!
- Bill
tighten them by hand you dont need to over do them and a little lock tight never hurt anything just dont use it on spark plugs lol
Hi -
The saga continues after a break to investigate fuel starvation on my other vehicle.
I am still in the 'diagnosis' phase and am almost finished removing the head.
I have removed the serpentine belt, manifolds and have the studs out too but the head seems to be glued to the block and I can't see an obvious place to apply a pry bar.
I've banged on the forward and rear cam bearing mounts to no avail.
Suggestions?
Thanks!
- Bill
If you have a pry bar that has a plastic covered handle, take the covered handle and put it into a intake, or exhaust port and give it yank.
Thanks!!!
Will do!
