That's the screwdriver and stopwatch test. Zap yourself and time how long until you can feel your arm again.
I thought that was the weak(yellow) or strong(blue) spark test
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
I thought that was the weak(yellow) or strong(blue) spark test![]()
^ this is good to know for sure, and will keep that in the back of my mind.depends on OHM meter but 0.5 to 0.8 would be expected, under 0.4 seems too low
Take your meter with you to the parts store and test the new one to see
There is no test for a "good" coil, you can only test for a "bad" coil, and not showing its a bad coil doesn't mean its a good coil, lol
Did you replace the distributor or just the cap and rotor? The pickup coil is inside the distributor and could be the cause of the no spark problem. But your ignition and slow start problems are probably two different problems.Fast forward I do the plugs coil and dizzy with no change.
