RangerDon1951
Talked to Ford Performance. Converting from a 2.9 to a 2.3 Ecoboost. I will need to upgrade my rear end to the 8.5 differential. Explorer with 31 spline is recommended. Would need to convert the power steering to an electric format which I need help with. Suggestions? Is the stock front 4x4 axle adequate? Will buy a packgage with a 6 speed manual. Would like to convert to electric windows and doors. Doable? Want to upgrade all around with the braking system. I am not interested in lifting the body. I rather go with some performance shocks and strengthen the sway bars from front and back. I am assuming a totally new fuel system from tank to fuel lines and pump. I like the 15 inch rims on there now. Stay with the metallic Ford Oval Blue for paint. Retain the ivory two tone trim on the bottom. Body and bed is in pristine condition.
So, buy the major components or find a donor Bronco that is relatively new. Suggestions?
Plan B would be shorten the truck bed a bit and convert the extended cab to 4 doors and a true back seat. Cannabalize two door to adapt with a post in between? Maybe even go "suicide" style? That gets pricey.
