99 2.5 ranger 170k miles. Getting fuel and spark and have checked all systems over. It will not crank unless on starting fluid. Compression test with two kits yielded: Cylinder 1-165 Cylinder 2- 140 Cylinder 3- 90 Cylinder 4-155
Could the low compression in cylinder 3 be causing my no run issue. Is there a common problem with compression caused by valves or rings etc on this truck? Thanks!
