- Aug 7, 2007
Please do tell the class just how Torque, Horsepower, acceleration are all related. Especially the part how "engine out put is not important". Silly me, if I had only known the engine output was not important, I would have removed my engine a long time ago. After all if it's not important it must just be dead weight, and I could really use the extra room for more wheel'n gear.
Let's misread a statement and then go nuts on it, shall we?
Torque at the axles CAN BE MADE ANY VALUE WHATSOEVER, regardless of what the engine is putting out. That's what gears do. That's why ignoring your transmission and rear end is foolish. It's the axles (and tires) that accelerate your vehicle.
I don't know everyone's motivations, but at least some of it is "penis comparison." Peak horsepower is an irrelevant statistic if the driver never even gets to the torque peak (and that's unfortunately rather common).If engine output is not important, why is eveyone trying to stuff a v8 where their v6 was? Why is everyone dicking with chip's, airbox's, and ignitions?
Because that's what people pay money for. If there are a lot of fools around, there will be people trying to take advantage of them. For instance, Slick 50 sells a lot of crap, even after the FTC nailed them.Why is the majority of the crap sold in Summit, Jeg's, PAW, etc... all geard toward increasing engine output?
No, messing with transmission shift points doesn't affect starting from a dead stop, simply because you can't downshift out of 1st gear. Differential gearing and tire sizes do. Do you REALLY mean to say you're drag racing a truck while towing? Or are you just mixing your issues? A tow vehicle is not a race vehicle. You said this was a daily driver that you wanted to tow your boat.Besides a shift kit will not magically increase the capacity of what it can handle or how fast it will accelerate from a dead stop. It will magically improve ET's on the drag strip and how long it can handle it's max capacity, because of how it shifts and locks up. It can help with many other things, but unless you mess with the actual gearing in the tranny it dont do, do do when it comes to actual pulling power.
OK, where did I say it would destroy your engine? I said it might make it run worse. That's really not close.I'm not even going to address the octane and detonation, other than to say. Yeah it does help w/that. Duh, no SH*T, I never said it did'nt. I will say, running 91 in a regular every day car will NOT ruin the engine. Yes, it will be an incredible waste of money, but it will NOT harm anything.
Older AVGas is illegal because it is (heavily) leaded. Newer ("low lead") AVGas isn't entirely lead free either. Gasohol is called "winter blend" these days, because of some questionable statistics about emissions (it's an oxygenate, but it has less energy content).What if Someone ran some AV gas? Would that have any measureale difference? What if someone ran some Gasahol?
Nitromethane blends have a wildly different mixture than gasoline, so that's going to be a bit of an emissions problem. Pure nitromethane probably won't light off at all in a gasoline engine... You would do better to ask about nitrous oxide.What if somone mixed some nitromethane up and put it on the sniffer?
& I also ended up bending a shift fork causing my tranny to lock into 4th.
