- Jun 16, 2010
- Manual
I have a 2000 2.5L 5sp and the computer is throwing out the above code. Where is the CMP located and has anyone else had this problem. A lil more about the truck. The motor has 190k on it and I just replaced the timing belt. The timing is good and it runs fine, just needing to get rid of the code.
Also has anyone had a problem with the engine slowly going back down to idle when shifting gears. Kinda hard to explain but it doesn't do it when you give it throttle while sitting still but as soon as you start going and go to shift it does it. Don't understand what could cause this. Can anyone shed some light on the problem for me, it would be greatly appreciated.
