Cobra Brake Swap
00RangerXLT
Muskegon, Michigan
I am going to get lightning rims this summer. I want to get different brakes so I want to do a cobra brake swap on my Ranger. This is possible??? thanks
yes it is actually pretty simple to do, but not cheap. send an email to info@nekustoms.com to get the kit for the front. you have to supply you own rotors and calipers. the kit from nekustoms is $365, its new hubs and caliper brackets. to mount it its just like a brake job, you pack the bearings and install the hub, the caliper attaches to the the bracket and you bolt it on. to mate the line to the caliper you have to drill it out to 7/16s for the banjo bolt to fit and bend it a little.
For the rear you can get a bracket from fortes motor sport or north race cars. it replaces your drum backing plate and bolts right in. for the brake line in the rear you have to bend the stock line to run next to the outside of the leaf spring and it bolts directly to the cobra soft line, then you bolt it right to the caliper. ( note this is for 7.5 or 28spline 8.8 only in the rear)
Cobra Brake Swap
Cobra Brake Swap
