b2redneck
First time poster...'85 B2, 2.8L, 4x4, 5spd manual, 178K.
Bought this B2 a month ago for a toy. Love it, great truck; been fixing one noise at time...Ran in to a problem coming home from work yesterday.
Went to shift and was not able to put it in to gear. Coasted to a stop in a parking lot to investigate.
Turned off the motor --> and the shifter went in to gear with little resistance. When I started the engine while in gear (clutch down and foot on brake) it wanted to take off all by itself.
It felt like holding the clutch pedal down was doing absolutely nothing to disengage the clutch. Same issue as b4 while driving home... holding the clutch pedal down would still not allow me to change gears.
Been reading up on some old posts, came across similar topics... does this type of problem sound familiar?
To me, it sounds like a hydraulic issue...master cylinder or slave. The clutch is old, but is not slipping.
Looked for leaks, didn't notice anything unusual, the resevoir is full.
Was going to try to bleed the system, but stupid me...I can't locate the bleeder screw (unless i'm staring right at it).... my thought was if I got air, then there's the problem. If I got no fluid moving, the master is out.
Any thoughts/suggestions here? Am I going in the right direction? What are some other things to check for?
Thanks.
Thanks.
