Clunking in front end
Wilson, NC
Clunking noise in front end when moving at any speed. I removed the driveshaft and it still does it, so I know it's not the cv joint. I jacked up each front wheel individually and can turn the wheel about 1/4 turn and it gets in a bind. Does it with both sides.
Welcome to the site.
The hubs maybe stuck in the lock position. I would check the boots to see if they are torn. Then grab the axle shaft and see if it moves in any direction other than turning.
