Clear Corners.
koda6966
The green part of NY.
Im thinking about buying a set of clear corners for my Ranger.
Is there anything special im going to need to know/do or is it just an easy job?
very easy. one bolt holds each lens in (i want to say 7/16?).
looks great when your done too:
Clear Corners.
i was thinking of doing the same thing on my 98. if i replace the corner i have to replace the turn signal too so should i do the head light as well?
hmm.. im not sure.
I was thinking i might replace my headlight as well, because its gonna look kinda dulled out next to a shiny new corner.
shine the headlamp up start off with 400 wet sandpaper & then 600, then 800,then 1200 after all stages are done & the headlamp has been wiped clean, then buff it with rubbing compound & wipe off the residue if any. Looks shiny & new again
