Chug or lurch from rear axle???
Status
Not open for further replies.
2002B4Grand
Gray, KY
I need some help. Got a 2001 ranger edge and as it goes up a hill, it seems like there is a chug or a jump from the rear axle. It seems kind of intermittent. I know there is some type of sensor on the rear differfential. Could this sensor be my problem? Any help or guidance from all of you pros out there would be greatly appreciated! Thanks!!!
Sent from my SPH-D700 using Tapatalk 2
Check the rear u-joints and/or carrier bearing in the driveshaft if you have one. Also check for excessive slop in the differential, there will be some play but too much (like if the pinion bearings are shot) it can flop around. Usually that will kill the pinion seal too.
The vehicle speed senser has nothing to do with it.
Please don't cross post is multiple sections of the forums.
Status
