- Oct 7, 2010
89 2.9 4x4
Running the truck at idle, warmed up or not it seems to choke before it revs up. In neutral I can punch the pedal and it seems like it just chokes, then revs up, does it if I do it by hand to. If it hasn't been run that day, when I go to start it, it takes a few tries to get it going. Giving it gas after it catches kills it right away. It'll usually fire up by the 3rd of 4th try, but I have to let it idle, then it'll die, because if I give it gas it'll die right away. Usually after that it starts up just fine. I've put a new fuel pump and filter in it, the tank was cleaned out when I put the pump in. I read on another post someone that was having a similar issue and everyone cited the TPS unit. Any ideas on that being the culprit for everything here?
