Briefly.... check engine light on a 2004 Ranger... O'Reilly's report said it was the sending unit electrical signal that was wrong. Bought a lifetime guaranteed fuel pump/sending unit from A1. Removed bed, replaced the unit. To do this you have to disconnect the fuel pump relay, run the motor out of gas, then disconnect the battery. I did, fairly easy install, screwed up the relay so bought a new one, everything is fine. Took the grandkids fishing yesterday and on the way home, the check engine light came on..... I would bet it is the same problem.... Read some forums that said the error code light may still come back on after the fix and stay on until it recycles several times.... True? and.. If I take it to my mechanic who I usually hire but did this one myself, can he shut off the light and clear the error code for good? or should I just try the cycle it several times and be patient?
