Cheap wheels for big tires ?
Back spacing is the one thing that will or will not make them fit. 10" is great for the tire size. Measure twice and mount once!
Dave
I was looking at this wheel, but my friend says a 10" wheel is technically too wide for 12.50 tire, is this true ??
http://www.summitracing.com/parts/CRR-3975112/
They'd be like $251.00 shipped which I'm good with.
that's what I was going to suggest - Cragar soft 8's from summit.
If your not in a hurry, keep checking craigslist/classifieds for a used set, you can get some good deals, but you always have the risk of buying something that's bent, just inpect them well when you buy.
Most 33" tire ads suggest an 8.5" - 11" wheel width, suggesting that an 8" width is too small, although many of us run that, and I would suggest running an 8" with 33's on your TTB because of the camber change during suspension flex. I always thought that wider would make the tire wear problems worse.
Would a 33x15.5R15 fit ??? Or would that rub, I believe it said 3.5 backspacing
