Cheap fog lights
sfwjesse
New Hampshire
Just an FYI for you cheapos out there like myself. If you have a 93 ranger with fog light(and whatever other years use those fog lights), im sure you have lost the glass piece long ago and now have big gray craters with a rust covered bulb in the middle. I am also sure that you checked everywhere and the cheapest replacement was on ebay for 70$. Rest assured, there is hope for you.
Go to walmart, item #004953803150 on my receipt, $10 each. These fog lamps were the perfect diameter, and the only mod i had to do was unbolt the little swiveling bracket and flip it over and rebolt it. They fit great, seem pretty bright, and look awesome. I will post some before and after pics. :headbang:
BEFORE
Cheap fog lights
AFTER:
Cheap fog lights
Cheap fog lights
You totally just helped me out BIG TIME.
I've wanted a fog light valance and JUST threw out my old regular one, and the only thing holding me back was I couldn't find cheap lights. Thanks!
Would this happen to be on the Walmart website by any chance? Hopefully it's not a local walmart only thing.
What are you going to do about brackets? I've seen people buy the valance, but are stuck since they have no brackets.
got my lights on ebay cheap for 20 each. found another place that sells the lights plus the housing (not the brackets, those are 170 from ford) anyways lights plus housing for 30.
http://www.blueovalindustries.com/products.php?catID=9902071
another member on here showed me those so i thought i would pass it on. btw its a good idea when doing the fog light mod on a ranger that didnt come with them to get thos instead of the ebay ones because they come with the housings...
if its on the walmart website you can have them ship it to your store for free and pick them up
With these lights i used the old brackets. The lights had a deeper housing but the threaded rod was short, so it worked out they were the same depth. The threaded rod was a little too low for the bracket hole, but if u flipped over the swiveling bracket the threaded rod is in, it lined up perfect.
Those ford brackets are something rugged....i believe they are expensive. If you didnt already have fog lights before then maybe you can find them at the junkyard.
and no, i tried to find it on their website but it sucks. I cant find automotive stuff on there. Hopefully it isnt a local thing.
you need to de-fog those head lights. its easy and takes like 10 mins max.
What is the brand name of these lights? (or is it a Wal-Mart house brand?)
i made the brakets for the 93 we had bending a small piece of metal it L shape and bolting it in the chassis, sorry i dont have pics
It was some no name brand...believe walmart house brand. They were in the fog light section, but i think they called them "utility lights" or something....said they were good for tractors and trucks and anything else you wanted to put them on.
Found the package. They are "Rally manufacturing inc.", NO. 3150......at www.rallymfg.com...unfortunately the website is awful and you cant find the part. The package calls these "55 Watt multi-use utility light, ULTRA BEAM"......LOL gotta love taiwan
