- Aug 9, 2007
- Harrisburg PA
- Automatic
I'm using the TFI Worksheet and everything checks out but my lite at the coil plug doesn't blink (no lite at all) when I crank the engine and the ignition ground on the TFI connector that plugs into the distributor reads infinity (no ground). This is the Black /Orange wire and I traced it back into the EEC box.
So far I have swapped out the whole dist. with a working TIF module, and a new coil I had. Still no spark. I had the dist, ignition module and coil, everything but the EEC. Is this a case of having everything but the right thing or should I look for something else. Forgot to mention. I've cleaned off all the ground wires I could find, put star washers on them and tightened them.
