- Jan 14, 2009
- SoCal
- Total Lift
- 4.5" SL
- Total Drop
- WWWhhhaaattt !?!
- Tire Size
- 33 x 12.50
Coax does get old and needs to be replaced but the main problem in a mobile setup is the bends and damaged sections; these cause all kinds of problems.
Get some new coax, Belden,Tune the system for lowest SWR (a must) as Tom 994 stated and see what is happening, can't hurt.
Another thing, I found through experience that a good ground is needed and I do not mean the coax shield to the antenna but the mount where the antenna mounts need to be grounded to the frame, a good electrical ground.
Also, the 4 foot antenna, mounted to the bumper of a Ranger, equates to the top of the antenna a little over the bed of the vehicle, directly in line for all of the Cab noise and could be picking up Fuel Pump noise.
Here is something I would try, either borrow a good Magnet mount antenna setup or buy one for a trial run (return it if it doesn't work) place the antenna/mag mount on the roof centered on the vehicle.
Run the coax through the window don't squash it in the door (you might need to return it) chk the SWR, just for grins, hook it up and turn on the CB.
Before starting the truck chk for noise level, with and without the coax from the CB, now do the same with the engine running; this will determine if the noise is coming through the wiring or antenna.
It is a process of elimination and the big problem is that you will never eliminate all of the noise.
