Cat question
they do it by converting harmful chains of gasses into simpler, less harmful gasses....as well as continueing to burn unburnt hydrocarbons rather than spitting them into the atmosphere. nitrogen oxide and carbon monoxide are both worse for you than the gasses the converter makes them into (nitrogen, oxygen, and carbon dioxide).
ok so teach me in hear to learn
how much will a cat improve gag mallage and reduse emmistons
im currently not running one so tell me make me want to put a new one on
im not here to convince you to run one. im here to state facts.
cat converters reduce harmful emissions by converting them to less harmful gasses. NOx leads to smog, acid rain, and contributes to global warming (blah, blah, blah). CO is, of coarse, an oderless, colorless gas that is extremely toxic to humans. partially burnt hydrocarbons also add to smog and have been known to cause cancer if the concentration is high enough. converters are very effective at reducing all 3 of these pollutants.
a properly functioning (not clogged) cat converter will have zero effect on mileage or power one way or the other.
i realize i sound like a greenie weenie defending converters like this. in reality, environmentalists annoy the hell out of me, as do any extremist groups. but due to the fact that catyletic converters do not have any negitive side effects, and i dont have to go out of my way to utilize one, means i see no reason NOT to use one....and i especially wouldnt go out of my way to disable one. the fact that its highly illegal to remove a converter is just icing on the cake. you can do whatever you want. but suggesting other people follow suite without properly informing them first is selfish, rude, and ignorant.
i replaced the double on my 95 4.0 4x4 ranger with a high flow from walker for about 100.00...sounds fine, a little more power...and definitely less heat to the trans area....
I just picked up a new cat for my '96 2.3L from summit racing for fairly short money (for a cat); it's a straight bolt-on and fully stainless.
Check it out
