PlumCrazy
<<--Live Rangerously-->>
⭐Supporting Member
💻 TRS Socials
2014 Truck of The Year
Boosted (Not Stock)
- Sep 22, 2008
- Millersport, OH
- State - Country
- OH - USA
- Vehicle
- Ford Ranger
- Manual
I am making some extended radius arms to go with my 4 inch lift. My question is, Where do I measure the caster from? Am I basically setting the pinion angle? Should the axle beam lean forward or be 100% vertical? I know the rear pinion is set at 6 or 6.5 degrees, but the front shaft is shorter, so should the pinion angle be a little more aggresive?
-plumcrazy
-plumcrazy
