caster camber
s2pidyeah
20+ Year Member
Ewa Beach
what do i need to adjust my caster/camber on my lifted ranger. i maxed out da stock eccentric bolt but not enough.can someone help and post a link of the stuff i need?
any alignment shop should have a selection of bushings in stock. if nothing else, your ford dealer will have them.
Install them yourself as well cuz the price the shop charges is outragous and the install is easy and only takes minutes
its a flate rate per book time........and good luck with trying to remove 12 point bolt thats oe, never been out and in the salt belt.
whats da goin rate?
we charge
1 alignment
2 bushings
install 2 bushings
probably around $150
napa part number on the most adjustable bushing is #264-3950 (thats going off a 92 ranger 4x4 as you never listed your year etc of your truck).
If you do take it to a shop, then for the love of god find a shop with somebody who is knowledgeable on the TTB susp. or atleast understands it. Other wise you will be throwing your money away.
