duraspark fast idle
time has been re-set at 10 deg BTC . valves adjusted all known vacuum ports plugged. still not much better, cranks better, but idles around 1200 rpm. if you back off the curb idle screw to bring it down it just dies. i have squirted almost an entire can of starting fluid looking for vacuum leaks and none are apparent. could fuel pressure be an issue? it is the only thing not replaced during the duraspark conversion. it still back fires a little through the carb. it seems happy to run at 1200. i have not driven it yet just drive way work. thinking about pulling the intake and replacing the gasket or getting a rebuilt carb.
