Car Care Tips
KarenCaren
According to recent studies, 5 percent of all motor vehicle fatalities are clearly caused by automobile maintenance neglect. The following simple and inexpensive preventive checks will greatly extend the life of the vehicle, ensure safer operation and even benefit the environment.
Always consult your owner’s manual, but a good rule of thumb is to have the oil filter changed regularly, every 3,000 to 4,000 miles.
Have all fluids checked, including brake, power steering, transmission/transaxle, windshield washer solvent and antifreeze. These fluids play a large role in the safety and performance of the vehicle.
Check tire inflation. Under-inflated tires can result in a loss of fuel efficiency. This is the least expensive form of preventive and safety maintenance. Tires should be checked once a month.
Keep your engine tuned. A fouled spark plug or plugged/restricted fuel injector can reduce fuel efficiency as much as 30 percent.
Have the chassis lubricated frequently. This step extends the life of the moving components of the vehicle's suspension system.
Check battery cables and posts for corrosion and clean them as needed. The battery fluid should also be checked and filled if it is low, except in the case of maintenance-free batteries.
Have the lighting system checked frequently, including headlights, turn signals, and brake and tail lights.
Check windshield washer blades for cracks, tears and windshield contact. Replace them approximately once a year or sooner if streaking begins.
Inspect engine belts regularly. Worn belts will affect the engine performance. Look for cracks and missing sections or segments.
Have the air filtration system checked frequently. The air filter should be checked approximately every other oil change for clogging or damage. This system ensures that the vehicle is performing at its peak condition.
Always consult the vehicle owner's manual for individual service schedules as manufacturer maintenance requirements vary greatly.
Source: asashop.com
_______________________
Autopartswarehouse Coupons | Autopartswarehouse Blog
I wonder what the leading maintenance neglect issue is in these reports?
I'm betting the cops wiping up the goo site dirty windshields a lot of the time if they can't figure the hapless victim fell asleep at the wheel.
I would say that not filling the washer fluid is a major cause of accidents...I recently witnessed 6 multi-car pileups on the same highway on the same day within a one kilometer range...reason...slippery conditions and road spray...I had to clear my windshield constantly...until the traffic was bottlenecked by the accidents...
Of course not driving accordingly to the road condition would be a factor also...
If it is only five percent, really maintainance is so good that only a few holdouts that don't listen to logic anyway allow their vehicles to get to that state.
I see so many cars every day with underinflated tires that it isn't funny. The drivers are probably bitching about their gas mileage too.
